Project Frostbite 1 ton K5 build
chevys4life
chevys4life submitted a new Build:
84 K5 Project Frostbite 1 ton build
So I started this build a while ago and also have it posted on pirate4x4 but there is a lot of people on here that are not on pirate so I figured I would show my work here as well. Lots of good tech on here and I love hearing peoples feedback. I will do my best to get all my other post on here as soon as possible. Thanks!
So im a little late starting this build thread but have a bunch of pictures and cool things to share with you guys! There is still a lot to do on the build that I am not done with yet so I will keep adding to this as I get more stuff done to it. This was suppose to be my budget build to get me out wheeling now since my big long build is taking a while but this is turning into more than i wanted to spend....lol
A little about the k5...its a 1984 Chevy K5 6.2 diesel that i got without a engine, tranny, and tcase. The k5 is rust free and has very few dings and dents thankfully! Basically all I bought it for was to use the frame and shell. Here is a ruff list of the main parts I am going to be putting in it....full roller 383 stroker engine, 93 nv4500 transmission, passenger drop np241, 14 bolt FF, chevy kingpin 60, and 37s. Here is what it looked like when I first picked it up.
Read more about this build here...
So I wasn't able to pull this into the shop for a couple months so in the mean time I started getting the engine all done up and ready to go in. I originally had this engine in one of my other chevys but pulled it out to use in the k5. This engine has always been a very strong running engine with a lot of low end torque so I figured it was perfect for the k5. Also there is less than 10,000 miles on the build of this engine. All I did to get it ready was reseal the whole thing, paint it, new distributor, and toss on a new carb I had laying around tell I can get my fuel injection kit.
Got the engine and transmission set into the k5 after a quick clean and some paint in the engine bay. Ive done a couple of these nv4500 swaps before into squarebodies and they always fit so clean! You can also use the factory crossmember without any modifications which is nice!
Got the axles pulled in and the front all cleaned up and painted. Also got the rear axle brackets all stripped off and ready for mock up. Going to be running 4 inch springs in the front and a shackle flip in the rear for my lift. Working on the SYE for the tcase next so I can toss that in next to start mocking up the rear axle and setting my pinion angle.
Got the new leaf springs and front axle put in. For right now I am going to be running 4 inch super lift springs and then shortly down the road I will be taking them out to do the 52 swap and moving my axle forward a few inches so I can get some better clearance from the body and possibly put my 40s on. But for now the 4 inch k5 springs will work fine. If I end up getting a wild hair I might end up yarding out the 52 swap idea and just bite the bullet and 4 link the front with coil overs!
Was also able to get the SYE done on the np241c this last weekend! Got the SYE kit that had the 1350 flange so I can run a front driveline from a 06 f350 super duty since it has a 1350 cv at the tcase and a 1350 ujoint at the axle. Just have to get it tossed in there then im ready for the rear axle.
The np241c I was able to get ended up having a VSS sensor for the speedo rather than the gear driven one id like to have. So I may end up looking for a gear driven tail housing so I can run the factory speedo gauge or I might convert it to a electronic speedo gauge. So if any of you have a mechanical speedo tail housing for sale let me know! lol
Nice progress, moving quickly!
Thanks! Its a little further than that Im just trying to get my post all caught up with what Ive already posted on pirate. Seems to take longer than I thought :/ lol
Since im waiting on my shackle flip brackets to come in I figured I would start working on the clutch pedal setup. So ive done several other nv4500 swaps into square bodies and used the factory clutch pedal assemblies from a square body and done a custom line setup between the slave and master but they are getting a lot harder to find so I figured id try a different route with this one to save a little money. For this setup I plan to use the factory clutch bracket from the 93 chevy since it is fairly compact and is a separate bracket from the brake bracket. Using this bracket will also allow me to use the master, slave, and line from the 93 making it nice for getting parts since you can get them in a already preblead kit. Its also nice to not have to worry about doing a custom line in case theres ever a failure of the line I can just go to the parts store and get a line from a 93.
First I started by making a template of the clutch bracket so I could cut out the hole for the master and the bolt holes. Once I got the holes cut I started cutting up the bracket and fitting it into place. So far everything is fitting well and the bracket is clearing fairly well. I am very happy that this is working out good since the bracket from a 93 I picked up for $10 vs the $300 ive paid in the past for a hydraulic pedal assembly from a square body. Heres a few pics of the bracket i using and what ive done so far. I will have to get some pictures of the bracket after i got done modifying it.
The only part of the clutch I have had to modify is the actual bracket but I may end up having to modify the clutch arm to get it all aligned perfectly.
