Very interesting, never would have thought to put a plug in that spot. Honest question: what is your purpose behind mounting a 110v plug in that area, just for electricity around camp or?
As always, I like your attention to detail.
Goes to his dual bank battery charger. If he spliced into it he could also hook it into an engine block heater.
Its not an outlet for power out. its a port plug for power in (notice its male) to power the charger. All i do is park it and plug it in done. no hood raising or juggling of charger and wires.
Any reason you couldn't put a Y on the back of the plug into a heater and charger?
Then, in the summer, you could just leave the heater unplugged.
Seems like it would keep the fender cleaner....and keep you from having to use 2 cords to power both heater and charger.
CHECK OUT THE BIG BRAIN ON DHCOMP!
Looks good.
No little ramp for the latch so you don't have to manually engage it in the open position?
While you have the springs off.................. whats the inside measurement (width) of the front spring pockets?
I've been told it should be 3.5 but I keep hearing that the 88 and up are different.
I see some nice short tires to roll it out with in this pic....................
