Located a set of 2005 aluminum wheels with roller tires today. I'll go pick them up Monday.
So for good measure, here is a short cost breakdown on the parts for the install of the ford front axle so far.
Front super 60 complete--300.00 salvage yard
Radius arm kit Ruff stuff off-road----499.00
Coil over mount ". ". ". ---- 39.00
Frame outrigger. " ' " ". ---- 69.00
Coil over shocks----- undetermined
Track bar bracket------undetermined
Coil over spring hoops-----undetermined
Now then, I think it would be absolutely possibly to use the stock arms. Fabricate a rear bracket on the Chevy frame and rock on. Now I am certain that it won't flex for crap. So if someone coming behind me wanted to get this done cheaper, that's what I would do. I don't but you might.
I am looking a coil overs now but honestly until the axle is under the truck with some sort of established ride height there is no way to know what to order. The track bar bracket will likely have to be fabricated once I know what I am dealing with there. Not a big deal but I figured I would include it. Shock hoops and crossover bar will come from ORD most likely.
