They are SAE, so that kit should work. Just make sure to follow the instructions to make a double flair.
The prebent outfit is here.
http://www.inlinetube.com/
They are pricey, and not worth it for one line if the rest are good. I had some rust issues on the rear lines to my Ford, so I bought the stainless kit. I replaced all the rear lines, they fit perfectly and were a match for the original. Even had the guards where the original ones did.
I have the front lines put up, and the next time I am doing anything major up front, I am going to change them too.
However, if the part you broke is not too complicated, look into the premade lines at most of the parts stores.
They are just straight lines with flare fittings on each end.
You can tie a piece of string to one on the truck fitting, run the string along where the line has to go, and then stretch it out straight to see how long the tubing has to be before bending.
Be sure to tape up both ends when installing until you are ready to hook it up so that you don't get dirt in the line.
If I ever have to do a line replacement where there is no prebent kit, I am going to try this stuff. I like the way it seems.
http://www.fedhillusa.com/
