I would think that the bigger engine would be more comfortable and not need more cooling to do the same job.If I used the old rad, the tranny cooler lines would fit, but I'd have to make custom oil cooler lines. I did have some temp problems towing with the 6.0 stock, but it all went away with a new fan clutch. I haven't verified that the 6.0 water pump is centered exactly like the 8.1, but the clutches and fans have the same mounting features.
Seems logical to run bigger rad with bigger engine. Goal is to be like it was all factory. I'm not held up by this for now, anyway.
I noticed that more on newer engines.
Older big blocks were giving me more trouble with heat but technology has changed.
I don't know.
