Should I consider running the factory radiator? It has the right fittings for the transmission lines, but the wrong ones for the radiator hoses. Raylar did this with one of their first conversions and said it works fine. There is some difference between the truck and SUV rads. I've read that the truck one only works with body lift. Anybody know if the shroud and or mounting brackets are different for SUV between BBC and SBC?
6.0L Suburban:
ACDELCO 21653 GM Original Equipment
Info
Trans. code 4L80-E; 3.73R(GT4); CORE SIZE 34 IN X 18-1/2IN X 1-1/8IN, CODE AJW,AFA,ACY,ARY,APA,ATW, Transmission Oil Cooler; 4 speed Automatic trans.
8.1L Suburban:
ACDELCO 21729 {#21492, 89019168} GM Original Equipment
Info
Trans. code 4L85-E; ENGINE OIL COOLING SYSTEM(KC4); CORE SIZE 19 13/32 X 37-3/4 X 1-3/8; 4 speed Automatic trans.
Silverado:
SPECTRA PREMIUM CU2948
4 speed trans.; w/ 37-13/16 in. x 19-7/16 in. x 1-1/4 in. Core; w/ Engine Oil Cooler; w/ Transmission Oil Cooler; w/ 3/8 Quick Connect Fittings
I suppose I should measure mine to be sure what it is. I have another radiator, but I think it came out of a 6.0L pickup. I've also heard that they went to bigger radiators in 1500s when they switched to e-fans in '04 or '05. Don't know if any change carried through to 2500s.
