GsxrMike
Are all th400/np205 combos 32 spline input/output?
So there is a long and short input as well as a long and short output? How do I tell the differance? What is a reasonable price for a 32 spline np205?
Fixed it for ya. If you want 32 spline front output you can swap one from a ford 205. Also with the short or long inputs. Most Doubler adapters require the short input. Sumner machine's doubler adapter is the only one I know of that can use the long inputThere are only fixed or slip outputs. I suppose you could call the slip a long output though.
There are a few variations of the Chevy 205.
There are 10, 27, 32 spline inputs
Short or long 32 spline input
Fixed rear yoke
Slip rear yoke
10 spline front output
30 spline front output
front yoke output
front flange output
Round or figure 8 bolt patterns
As you can see there are quite a few variations to choose from. You can't get everything you may want in one unit though without swapping parts.
The long input is only found on the round pattern 205's 1985 and later. It sticks out like 4"s or so. The short input sticks out just over an 1", I beleiveSo there is a long and short input as well as a long and short output? How do I tell the differance? What is a reasonable price for a 32 spline np205?
In stock form, The long input is only found on the round pattern 205's 1985 and later. It sticks out like 4"s or so. The short input sticks out just over an 1", I beleive
