<font color="green"> Wow, I was avoiding posting in this thread, but since Zakk brought my name up I'll chime in. I ran 38" Radial TSLs on a D44/12 bolt ocmbo for 2 years. I was busting a fair amount of joints and shafts in the front so I went for the Warn shafts and added the Premium hubs to it. I also had a full-case L/S in it to keep the carrier from being the weak link. I still busted joints, broke a couple of the shafts to but it cut down on the breakage a good bit. That is until I started breaking ring gears. I replaced one , when the second went 8 months later I threw in the towel and parked the truck until I could go 1 ton. I was not about to put any more money into it. As a sidenote, I sold the Power-Lok L/S to someone, and ended up paying for a new side gear for it since he emailed me to tell me that one of the ones that was in the unit was broken. This L/S had less than 10,000 miles on it.
The 12 bolt faired much better. 1 broken stock shaft and a broken Auburn L/S, but when I pulled the cover after the front end puked the second ring gear, the gears in the rearend looked worn pretty badly. These were the factory 4.10s.
I put about $1600 into the 44, had I continue on the path that I was planning on at the time, beefing the 44, I would have been into it for alot more. CTM joints and all that stuff, although the CTMs weren't available when I parked the truck. I was into the 12 for much less, basically just Moser shafts and the Auburn, so around $700. I bought my D60/14bolt for $1200, but put another $1700 into them right away. That does include a better gear ratio for my needs and an ARB. So the final tally for me was about $2300 into my 1/2 ton stuff before I gave up on it, and about $2900 into the 1 ton junk so far. It cost me more now, but should last longer and give me less frustration.
Jeff, have you ever measured out those Ground Hawgs? I didn't think they were 39.5, they look more like 37s or 38s. Maybe the reason that you've had such good luck is because the Hawgs don't offer quite the traction that a Swamper does? Just a thought... I was pretty smart with my 1/2 ton stuff, they were built as well as possible at the time and I am not throttle-happy at all. I tend to wheel with finesse.
By the way, I can testify that Jeff does get it with his 1/2 ton stuff, I was there a few weeks back and he certainly didn't baby it. Not alot of traction out there either though, to be fair. It was a creekbed so the tires were wet ALOT. [Forrest Gump]And that's all I have to say about that.[/Forrest Gump]</font color>
