Haha.
Martin
Martin
Hmmm, that one is definitely pretty unique Dueling
7/8 x 3/4 heim joint to tie in to the main tube instead of a long PITA cope.
Yours is the third one I have noticed with the lower bar being the longer bar. Is there a benefit to doing it one way or the other?
Martin
If you don't want to cut the long angle, why not just cap the tube and weld to a long tab there or something? Seems like if the heim isn't actually a rigid mount that it's not really doing anything. Are they cheap?
The heim IS serving as a rigid mount for the top tube end. It is not meant to resist twisting but rather a longitudinal bending action. The heim and shackle at the crossmember take care of all the twisting and push/pull action from axle articulation. The gusset idea you suggested would have worked too but I don't think it would look as good. I still choose the heim even if I had to do it over. It was $20 for the heim and $10 for the tube adapter so its not like its sending me to the poor house. The kit itself was $250 shipped and that was after a 20% discount so that's where the real money is.
With your gusset welded to both tubes, that heim is doing absolutely nothing.... You could have just ran those tabs up to the tubes and welded it all.
The only thing it would be any good for, is having a little adjustment in the angle before you welded that gusset in. Now its just a shiny end of the tube.
Yes, but that is the whole point, it was a way for me to terminate the upper tube cleanly without doing (1) a long cope which I don't like making or looking at or (2) having tabs welded to the upper tube and lower tube like patch plates
I feel like (2) would have looked even worse than the cope especially with the long center gusset.
I think you just don't like it because there aren't any dimple dies used![]()
It is definitely unnecessary, but it isn't hurting anything.
Martin
I already said I liked it. It is a nice antiwrap bar.
Just was saying that really, besides looking cool, that heim is no longer serving much real purpose.
I have Kert's backbone installed and I was planning on using a heim similar to what truck-oholic used however I wasn't planning on plating the gap between the two tubes so the heim is functional. With the ant-wrap up above the driveshaft I'm not concerned with dragging it on rocks so I don't think I need to add anything between the two tubes![]()
