Also, double check your rear u-bolts and center pins Adam, I broke a center pin once and didn't know it, caused the rear to want to pull to one side under power since the axle wasn't straight anymore.
They are literally brand new, and the ford springs have much bigger center pins than the 3/8" ones in the chevy springs. Also u bolts are tight.
Ill just deal with it I think. I doubt ill notice it in the sand, building another track bar would be a waist of time unless I can use them as trailing arms later.....
