The pickle fork will damage the boots but the hammer on the stud can damage threads even with a nut on it.
Does damage matter if I'm replacing it all anyway, drag link and boots? If I just do the boots then a pickle fork would suffice, if replacing it all a hammer is what's needed?The pickle fork will damage the boots but the hammer on the stud can damage threads even with a nut on it.
Just be ready for what might sound like gunfire.Thanks.
I may just head to HB to pick this up.
Tie Rod and Pitman Arm Puller
Amazing deals on this Tie Rod And Pitman Arm Puller at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Like this? At.35 sec
Thanks for the tips...Good idea to measure the width at the steering arm and pitman arm. They may need different pullers. Avoid hammering the puller on if it's too tight, as I've never bent one without it breaking later.
Had to remove both castle nuts.. sprayed the shiz out of it with wd40 cut the boot. Smacked a few dozen times. Tried pulley again and it pooped out
Looks awfully jagged.That’s the weld on steering box frame brace that someone followed the instructions on and didn’t fully weld it.
They ground them boogers downLooks awfully jagged.
Those are probably the boots for TRE, not DLE, hence the original title of this thread.These ORD ones sucked... had to use stock moog boots. They'd buckle or squish up. No matter what I did nothing worked. Waste of money.
Maybe sometimes, certainly not all times. I doubt it's even the majority.To get tie rod ends like that out just smack the arm where the stud goes through, pops right out, no puller needed and no boot destruction
