@Blue85 you're probably correct. I haven't investigated further. Yes, I made the title of this thread in error and have now fixed that.
Edit: according to ORD they should fit. I had no luck getting them to look correct when tightening them down. I tried everything @Wes Harden suggested.
www.offroaddesign.com
@Chickntrk I tried that to no avail. I was able to get the lower portion out first. Still the pitman portion wouldn't budge. Got the puller on there and it finally popped loose.
Replacement Polyurethane Tie Rod / Draglink End Boots, Pair
Replacement Polyurethane Tie Rod Boots, Pair
