ReTonkulous
Utlilmaster P30
Haven't heard of that brand before. But the artwork on the side is bothering my OCD. The "trunk" is upside down.
The owner was an original engineer for vintage air. Had a parting of the ways and started his own deal.
Othe side looks the same. Like you lift the box off of the base. But no.
Can't get web site to work this morning. Will check it out when I get home
Works for me. This is the one I bought. Bluetooth controlled through my phone.
That looks sweet. I bought a vintage air system because I didn't know any other brands. I haven't installed it yet, but I hope I like it.
That system looks pretty good, and it is cheaper than what I bought. :(
Update on the oil issue.
Finally did an oil change. Oil looked thin while draining. Changed everything out. Put Valvoline 10w-40 in it due to the heat of summer it will be driving in. I poured the old oil through the strainer for my heater in the garage. Most oil takes a couple of minutes for 5 quarts to run through. This stuff was 30 seconds, tops. :yikes:
Added the good stuff. 55psi cold still. Maybe a tiny bit more. At 185*, at idle, it now has a tick over 20psi. Crappy oil in a brand new build is stupid. I checked the old oil for gasoline smell or anything weird. Nothing. No metal on the drain plug or in the strainer. So I think I dodged a bullet.:woot:
