ReTonkulous
Utlilmaster P30
I need some input from people smarter that me.
I can not find anything that shows engine oil flow direction for the oil cooler. I need to tap the cooler line adapter block for a pressure sensor. I am running my Autometer gauges at this time and the OBDII does not feed oil pressure for digital gauges.
The adapter block has a front port that goes out the bottom line. One diagram that was GM and was close in design, has the lower going into the top of the cooler.
Does anyone have a clue which direction the oil flows?
@ZooMad75
@Fastereddie
I’ll see what I can dig up.
I was not aware, that I needed to shave a guide bar out of the oil pressure sensor and remove a block in another plug, on a plug and play harness.
my 2 wheel burn project got a line lock cause i needed a T-fitting and had one here so i used it . . . . cant wait to try it my self .
Computer mount is done and the paint is drying. Thought I would take 15 minutes and slap the starter in. Eat shield for the knock sensor needed finessing to clear the header. Took 45 minutes due to trying to align the knock sensor so the starter would clear. There is a round heat shield that goes over the sensor and takes up a bunch of space. Finally found its spot and everything went in.
I picked up the O2 sensors. Ordered up stream 2017 sensors. Nope the harness connector is for the down stream O2 sensors. What the heck?
