I haven't got that far into the videos yet.Once you get done towing your neighbor, and then doing a victory dance because you found magic, send me that transmission tuning video you were telling me about
Got me for a minute with the 4 wheel burnie; I was like this thing is a 4wd?! What did I miss? Then I remembered, oh yeah, dual rear.Well, I drove it. More than just reverse. Put the new TCM in. The TCM tune is so far off it went into limp mode within a 1/4 mile. Slipped so bad going into second on light throttle, I didn't think it was going to find second. Slipped a tiny bit into 3rd. Turned around immediately. 21 codes thrown. Mainly trans codes multiple times.
Put the original TCM back in it and, what do ya know? It shifted, did not go into limp mode. Did a 4 wheel burnie in the dirt. Still needs to be fine tuned for my gears and tire diameter.
Now the learning curve begins.
I hope so. I had to look a while to find stuff. It's been at least a decade.acid core solder and brazing tip = win win . .![]()
I'm not sure about the jets, definitely power valve related.Did you try changing the primary jets?
You must be old.fan relay are you doing ground switched ?
late model is now ground switched for control functions .
Yes.You running the Camaro ss pwm fan?
