moment hit me.That is where I am now. Going through it, checking settings.Not sure if your on any other sites or maybe have a tuner near you. But get someone else's working tune, and just upload it.
Use that one as a baseline for yours.
Only thing you may need to change is the injector numbers and possibly displacement.
Rest should be close enough to run.
30 gallons of premium over 10 gallons of junk.I think you have several things cooking, but hopefully this helps some
Did you get enough fresh fuel in this to cut it?
It's a stock engine and stock trans, it should run normal with the stock tune...am I missing something?Really frustrated with this.
I drove the truck 7 miles each way to a car show yesterday. Runs like crap.
Throttle response is that of a Yugo.
When I back off of the throttle I get what sounds like open exhaust valves through the exhaust and a couple of backfires????????????????????????
So many of the base settings were so far off, I could not drive it initially.
It will not get above 165 degrees. 2 different sending units in 2 different locations on 2 different gauges show the same thing at the same time. So I am going to say they are correct.
Back fired pulling to a stop at a signal that the Sheriff Deputy opened his car door behind me while looking around. My friend in front of me was looking around, so I did also.
Bought a new thermostat yesterday afternoon. Pulled the old one, it was closed, but who knows what it was doing. Installed the new 207* thermostat this afternoon. Same thing.
Then themoment hit me.
I am using the OEM radiator. Has the heater return in it. I did not have a way to cap it off, so I "t" it into the heater core line. On the hot side. So it had a 5/8" line running constantly. Switched that to the cold line and fixed.
Running at 208 right now.
So now I can start to try to figure out the other crap.
If it's stock, how wouldn't be 12:1?
Because the asshat he got the ecm from has a 5.3 tune in it. I got a 2017 6.2 tune from the repository and copy and pasted a hundred different tables into Wade’s tune and sent it to him.It's a stock engine and stock trans, it should run normal with the stock tune...am I missing something?
If you put larger tires behind the stock vehicle, it will still run fine, just the speedo will be off. So the fact that it's not running correctly means its not the correct stock tune for that engine or something else is wrong, you should not need to tune it to get it to run correctly, you should only need to tune it if you want to tweak some more ponies out of it and/or turn off the AFM, etc.
I suggest you find the correct stock tune and go from there, it shouldn't be that much trouble that it is causing you.
It is ~12:1 compression so you do need good gas.
I would like to give you an additional Thank You on Wade's behalf without Wade's permission.Because the asshat he got the ecm from has a 5.3 tune in it. I got a 2017 6.2 tune from the repository and copy and pasted a hundred different tables into Wade’s tune and sent it to him.
I have never messed with that so I’m not sure what it entails or does. I thought that was for changing transmission types or something along those lines. Wade’s tune/vin number is already licensed to his computer so I was just copy and pasting all the 6.2 settings into his. If that segment swap will do that without changing certain parameters like all the dtc stuff and whatever else he has already fixed like fans and charging. I would like to learn.Why won't a segment swap do it?
