ReTonkulous
Utlilmaster P30
bet a bulb element is shorted, or in backwards
All LED throughout.
My 1st guess would be hazards are on, (button bumped during all of the work) but the hazard flasher is not functioning. I have seen the headlight switch do that, but I thought that the turn signals still worked. I can't remember, it was too many years ago. And I don't know why it did it.
Just my 2 guesses... :dunno:
Very cool to see the pay-off on all of your work!!
:saweet:
Hazards? What are those?
No, I don't have hazards yet. Everything else was working 2 weeks ago. I added a couple of features under the dash before the tune. Something is not bueno.
My guess is bad ground on the turn signal circuit and when the brake is applied it’s back feeding….gotta remember brake and turn signal share a common power back to the light so if the brake lights are working and the turn signals aren’t it has to be on the turn signal side.
I may have done something stupid. Speedometer is 5mph slow. So 55 is 60. 0 - 60 in under 7 seconds. Lifts the front of the truck as it accelerates.
This truck has no bussiness doing this. Suspension has to be upgraded. The MAW process has officially been instituted.
The truck topped out at 65 MPH on the freeway before. I had to get on the brakes at the fwy end of the on ramp, with 1/2 throttle. I was doing 70mph with very light throttle on the way home.
I hated the exhaust note before I took it to the tuner. Now it drives nice and quiet, until I get on it. They know it is coming.
That's awesome Wade! Glad it's finally running like it's supposed to!
What does that thing weigh with the aluminum body and aluminum block the way it sits now?
You need some big wide prostreet style meats on the back to complete the look and hook too.
It was 5500 pounds before. I will run it up to the scale one day this week.
Been looking at wheels and tires. It is already tub'd.
