M.A.W.!
Rear has had multiple leafs removed and hangers moved.Yep. Might as well cut one coil and axle flip the rear too. Then you can walk into the truck instead of stepping UP into it.
It would look cool AND have old-person-friendly ingress and egress, lol.
Stock travel with the 3" drop spindle.One coil would be like a 3" drop in its own lol.
It is not stiff in the front end. Bags will go into the new chassis if I ever get to it.If it rides stiff now, wait till you cut a coil out... Which is why he should bag it instead.
It is not stiff in the front end. Bags will go into the new chassis, if I ever get to itIf it rides stiff now, wait till you cut a coil out... Which is why he should bag it instead.
Neither are your posting skillsIt took 1.5 hours to swap one spindle. My arms and fingers are not like they used to be.
No. Doesn't work like that lol.Is it not the same drop ratio as the typical C10-30? I thought one coil was 2" or less? So 5" total for the front and a flip in the rear would be around 5".
I could be wrong. I haven't lowered much stuff.
You set the flat part of the coil on the ground, measure to the center of the coil at the highest point, and start spinning the coil measuring the center until you've come down half of the amount you want to drop.
Mark and cut it there.
Rears you cut the actual amount you want to drop unless they're mounted mid control arm.. then there's math to do.
Been researching it a lot since I'm getting close to doing it.
Hijack off ..![]()
I have never cut a coil on anything. Set a jack under the frame 1/2" higher than final ride height. Heat very well. Let cool. Remove jack and go cruising.
I have to cut mine because they make a 3" drop spindle, which I have. But they don't make a 4" or 5", etc.
If you want more than 3" you'd have to.
