Fubeca
I bet you're right. It's hard to visualize - I can't wait to see it in the truck!
So the brown and the blue, are those the only thing supporting the receiver tube?
If you do go with the big receiver, they make a reducer to use the standard size receiver hitches in the large receiver.
Martin
Congratz on taking the plunge to make a real fab table
That 3/8 is gonna be a heavy mofo my friend.
Martin
I think that would be pretty handy. Only problems I see are getting it to lift all 4 corners together and not bind going up. Especially since your clearance between the two sliding tubes is going to need to be tight to give the table sturdiness. The things going to be heavy. Maybe in the center have a recessed spot for a cherry picker to lift up from?
