thanks guys.... the real-world insight is very helpful...
I'm just not sure how to get that kinda movement on it.. I mean I have a 10 ton portapower and such, but I just can't envision how to get that to meet a boxed frame in the middle..
and even than, if a 3" x 3" x 1/8" tube will keep it straight once welded..
logistically all I can think of is to put a front tire from Mutt down on it with the 3" x 3"s under it.. and obviously that brings up the issue of accessing the underside to weld.. I'd have to block it up some.. but my bigger concern is I don't think that's close to enough force/pressure to flatten that.. sure, 1/4", I think it would do it.. 3/8, not so much...
I suppose I could jack off the upper door frame of the garage with the porta power, but again, I'm not sure the porta power has enough snot... nor my house!
aiding in the straightening issue is the fact that the way I need to bend it down, is the narrow end of the table.. and the way I designed the table was so the long sides had the 3 x 3 inset about 3, 4" per side, and the one end one inset some from the edge.... so I can mount some drawers..
kinda like this....
the 4' side would be much easier to deal with...
heck, maybe they'll take pity on me and throw it in a big press and tweak the center down.. I'd be ok with that too..
