just douche em with some satin black.....
all of it...or do you like undercoat on the tub wells?
I kinda like rehitting em with satin paint every now and than.. undercoat looks great at first, but once it gets cr@ppy, it's hard to make it look good again... than if you keep recoating, it loads up..
that's me..
I put pure gasoline in it and bought a can of that 10+ Octane boost....I can report that it does NOT get better gas mileage....but my neck can report a much greater response when you hit the gas pedal...not kidding...don't think it's in my mind either...seemed to be much more responsive...
ethanol vs reg will have more of a dif.. boosters don't raise octane nearly as much as they would have you would think... not to mention, the majority of mills won't benefit from a higher octane anyway.. it's only raising it .10's of octane points...
running aviation fuel? yeah, that's an octane dif! but it only matters if your running 11 to 1 pistons...
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$A lot of newer cars run higher compression and need higher octane. My Bimmer calls for 91 for example. I'd say anything newer and boosted should get higher octane as well. The small and big blocks in our trucks though? 87 is just fine.
