How should I handle those "pits" that are on the curve...I think they filled, they look bad but I think they are smooth to the touch.
Do I just prime those and then fill them with glaze if there are any that show?
Also, did I ask you when or if I use a high build primer?
if they feel good, you can go right to prime.. just be aware that when priming, those spots may need to be "loaded up" a bit with primer to cover/fill well... you'll see when you prime, pinholey/pit kinda stuff sometimes don't fill in well and need a bit of a douching...
