FYI...the aftermarket quarter weighs exactly 50 Lbs.
They aren't as heavy as the originals, but they aren't that weak either. The issue seems to be the crappy quality control...bad spacing...measurements off...etc...
If you are looking for a "I told you so" then I say OK, your point has been made...the aftermarket stuff is not as good as the original....I found that out with the fenders.
But where do you suggest I get a set of originals?
My choices were to either to use a lot of filler, do extensive metal repairs on the originals I have or get aftermarket. Looks like either way I will have to do work to make them fit...that's what I was hoping to avoid, but too late for that...I can't send them back.
I will either make them fit or I will start cutting and patching the originals.
Are you putting down the 2K primer right ofter the Zinc primer?
I picked up a used Millermatic 120V Mig welder on the cheap on CL. I've been practicing spot welds on 22g metal using .030 flux core wire. This is so that I don't waste a lot of gas practicing. When I go to gas I'm going to use .023 wire. I found some good wire to use. ESAB easy grind. My plan is to cut and patch the originals while they are on the K5.
Been following this a while... This picture struck me as kinda funny given that this thread started out as a "fix a little rust on the top of the bed rail" and has turned into a "cut away and replace the entire quarterpanel". It's not a criticism but a reminder of how that always seems to happen on ck5.![]()
After having used both, I think I prefer the .030 wire....and practicing with flux core did me no good when I went to solid core and gas...they are so different it almost doesn't translate. Get ready to forget whatever speed and heat you got used to practicing with flux core...the gas is much, much cleaner but the feed and heat settings will be different. I am having a hard time with .023...I had much better results with the .030....don't know why.
That's because where there is a little rust, there is really a lot more rust...and I have no intentions of doing this again in 5 years....
Think I answered my own question....look...the original QP has the edge trimmed...the new one is full thickness all the way to the end....
Useless information for anybody interested
Original driver's side quarter panel weighs 60 pounds
LMC quarter panel weighs 50 pounds
Other factors: Original QP has paint and primer on it, tailgate lock things and bolts
I don't know how much that weighs, but probably a pound or two?
would you rather use the new panels or fix the old?
I went out there and tightened the bolts a bit on that panel and then put my hands on it and shook the truck...they feel pretty darn solid...enough so that it has eased my mind about them...and that's with just two bolts in it.
Let's wait and see when they are bolted and welded up....
Ryoken (Paul), on that B pillar....is it enough that I wire wheeled and wire brushed it an put Eastwood rust converter on it, or should it get the sandblaster?
