How thick of a shim should go on the body mount?
You need to try, use 1/8" shims, my guess you might need 1/4"How thick of a shim should go on the body mount?
#12 won't do anything, you can adjust that position with the hinges, you need #19
But that's way behind the door jamb....the "hump" will be somewhere in the bed floor...just in front of the wheel tubs
Will this be noticeable immediately or is it something that will "creep and bow" as you drive it?
anybody here ever put the upper door hinge pin in upside down with a keeper on it?
heard that this is the best way to go when you get your doors aligned...when you need to remover your door again just drop the pins and out she comes...![]()
chief check out the tech
http://coloradok5.com/doorhingepins.shtml
I just ordered some new brushing and pins for the door. I'm deciding if I should do the quick release.
Wow...I won't be needing to remove my doors much if any...but great idea..to make it more permanent you could use roll pins...or maybe set screws if you could thread it...and I could leave the splines on for extra grip...
my reason is really only for painting the door or assembly after painting...
Did you have the tab at the bottom of your door hinge pin? Did you end up cutting or grinding down the tab to remove the door?
Chief -
1. When you use the zinc chromate are you also using it over existing paint?
Spray the zinc on the bare metal...some will overspray onto the surrounding area...scuff it lightly with a scotch pad after it dries this will take it off the painted surfacesI'm going to sand down an area. Some will be bare metal and the other area will be the old paint that is feathered.
Nason 2k Urethane primer2. What do you paint on after the zinc chromate? What brand are you using?
3. How long can I wait between the zinc chromate and the next step?
I haven't read all the posts, but it appears the brotherhood has stepped up once again to help out....
It will show immediately.
You don't need to do this if you want to work on the gaps differently.
Just adjust the door to get a good gap at the quarter, then bend the door wing window to get the gap at the windshield.
at least not to the gap at the windshield and door sail
