Jester1
Quick idea to add to fordums suggestion. Run you corner post (and possibly mid studs) up another foot past the top of the walls and then roof with tarp or luan plywood. It will give you a thermal break in between the two tops thus dropping internal temps. Think heat shield. Plus the cool water on the concrete prior to spraying and the ventilation system may/should keep you to around 80 degrees on a 100 degree day.
Thoughts?
Oh and in the tarp is large enough you can drape it to the side you get the late afternoon sun away from the side wall if you end up painting onto the afternoon. Roll it up in the morning for light then drop for afternoon.
Thoughts?
