Been working alot, not much time for anything lately. The injector harness starting acting up with those adapters. I had to order all new pins and bodies for the ends. The last fix didn't work good so now it's all fixed.
A few things have changed, the cam package I thought about and changed my mind. I cancelled the order, spoke with a few people and a custom grind is needed for such a big heavy truck. I had cam motion cams custom grind done that was speced out perfectly for my truck. The specs went to 220-232, 587/578 114+2. Should work perfect, cam motion cut and shipped this in two weeks. I received it yesterday, also received all the rest last friday.
The rest of the internals came from brian tooley, .660 double platinum valve spring kit, 7.4 hardened 5/16 push rods and all the gaskets. From Colorado speed I bought a 10% overdrive crank pulley. Also innovators west 8 rib pulleys. I still need fluids and a gates 8 rib green belt.
