Not sure, it drives and looks good...lol.....drives pretty close to stock, way better than my ifs lift. Overall Rate the handling, driveability etc at a 95 it really handles good and drives excellent, no bump steer, wandering or anything
Ok..
1..i would prob try the ford steering that they used in the petersons mag, instead of messing with crossover/highsteer. just since it worked for them with ease. Then i could of used a regular trac bar mount on the axle and that would clear up more room. You can see in the pic2 above in post 113 that theres alot going on.
2..Spent more time and plated and smoothed the whole front frame rails to look cleaner, still might plate both sides of the coil buckets to hide the ifs control arm holes. (you can see in the pics of the frame and coil bucket)
3..I have the 8.5 lift coils, with them on my truck i had about 12....which sucked. I trimmed 2 full rings off so it would be close to the ride heigth. Which was fine, was jim coles(made the parts) idea and it worked real good. Would of been nice just to slide the correct ones in. Also cut them exact and each side of ride heigth is within a 1/8 inch. Was my fault i didnt order the 6.5 lift springs instead.
4..Should of done the whole thing years ago, now its a real truck....lol
"Check out the Bloody knuckle garage facebook page"
Ill add more when i think of it but its not a big deal, i 95 percent love the swap, i smile everytime i see it .....
