Happy Thanksgiving guys..!!!
Not really anything much going on.. I ran into a few problems with my coil overs, i wanted to swap the springs for softer ones. The top adjusting nuts bolt is bound up so i need to cut the bolt. On top of that one slider looks smashed so its not in good shape. That had me thinking about calling king, to check spring rates before i go thru all that. I had calculations done by brian at king. I had to measure my current spring length under weight and with it hanging. The amount of pre load i have now with my current springs is about perfect for the weight. The compression valving tho needs to be changed, i have .020 now so to soften it up 25% i'm going to .015s. That will take the edge off of the bounces, The springs will be the sames rates but set up different. The upper now is a 4 inch tall, it will be a 6 inch with the secondary stops set so the spring is 1/2 way compressed. The lower spring is now an 18, it will be a 16. So i ordered new valving, secondary nuts, sliders, adjusting nuts and eibach springs from poly performance since it was the best deal. Not too happy at a tune of 550.00 but hopefully its all taken care of. I have a fresh gallon of king shock oil too so i will change that when they are apart.
