School me on lockers please...
Well, after much shopping around, I placed my order tonight :D
I ordered an ARB locker for my D60, along with a 5.13 USA Standard Gear ring and pinion + install kit, and I ordered a Yukon 5.13 gear set and install kit for my 9.5" 14BSF to go on the existing ARB locker.
Hurray for good gearing and strong / reliable lockers -- Ouchy on the bank account!
Looks like I'll be looking for a Detroit for my 10bolt until I can afford a 14bff swap. Would the ARB for the front still be the way to go?
I am not sure about your area, but up here 14 bolt full floaters are cheap as dirt! Buy them for 2 - 300 all day long! Much cheaper than a Detroit and all the axle shafts you'll be going through with one :D
I've ran an ARB front in my 10b for many years with good luck; 4.56 gears, 35" tires. I've had a few axle shaft failures, some of these could be traced to lost u-joint clips. I modified my stock front axle shafts to accept a full circle clip, and that helped a lot; I've also had good luck with the good Spicer u-joints.
waste of cash there. 500ish for detroit and then full install job.
grab a lockright if anything.
or just bite the bullet 1 time and go 14ff and detroit for around 400-450.
Yep 10 bolt and detroit (in the rear) with even 35s means broken. It actually seems like they break less with a lock rite in them ? :dunno:
But if you plan to go 14 bolt then don't waste your time or money.
You can make it live certainly and I have never run a locker in a rear 10 bolt before, but I have wheeled with alot of guys that have. Only my bro in law running 36x12.5 swampers didn't break but he only wheeled in Moab.
If you dont mind could you pm me where you bought all the stuff for the 60 . Im looking to get a 5.13 r&p as well as a arb in the next few months as well.
