Yeah, if it's running at 210 steady, than it is running exactly like it should be.
Martin
Martin
most fuel injected motors run around 200.. my new 454 TBI runs 205, 210 steady...
well if you have a carb then you could probably put a lower T stat like Paul is suggesting.odd's are it's a 195 stat in there... put a 180 in....
I freakin hate carbs, Their one of the few things I've never gotten the hang of. They seem so simple. but even with a manual right infront of me, nothing seems to go the way it should when I play with em. this aluminum radiator can cool better then twice the size in copper/brass.This 1" thick radiator may have a small part to play in the heat dealI never really looked at it before
With the light on it the timing mark is straight on top
I dont know what'd cause this but it runs and thats all that matters. Its not quite right yet and deffinately running rich but its WAY better than before.
I didnt know that about the tabs. Going off the first pic (cant see the others from work
) This is where mines at.
I need to just take it to one of those old guys around that has never used a timing light and let him play for awhile
I think I know one near me too
I'll have to call him
I finally got to a long list of small things that need looked at too
) (Switch may need adjusted on column yet also)
