Looks stock height to me. Front springs flat or slightly negative arch is stock.
Rene
Rene
Also can anyone tell if my blazer has some sort of lift on it already? It has 33/12.50/r15 bfg a/t tires.
Yea i think it is stock i love this thing so much already! The motor is pretty dirty and oily....So tomarro i am going to take it to the car wash and spray a ton of engine degreaser on the block/oil pan....Then clean it up as much as i can then i will put new valve cover gaskets,oil pan gaskets.
Man i am so damn confused right now....The blazer use to be full time 4x4 but now it has warn locking hubs. The shift is wierd...It says 4wd low and 4wd low lock and 4wd high and 4wd high lock?
What do i put it in to be in 4x4? i think it only works in 4low lock and 4 high lock?
It has a 350 motor 350 trans and a 203 t case as far as i know.
When i put it in hi lock and low lock the front tires would spin but not when i put in in low and hi? unless i was doing somthing wrong but idk....
Aww ok i get what your saying...Everyone is telling that the np203 is junk and to put a 205 in? but forget that i am going to drive this thing until it breaks and then fix it.
A few posts back you were saying that if it broke, you could probably sell it and now you're saying "drive it till it breaks and then fix it!"
Amazing how quickly you can get attached to a great rig like a Blazer huh?
