chevysmithz71
your spring looks pretty flat, so it will not get any closer to the frame. if you stand it up it will ride rough.
Just like he said. Your spring can no longer compress and get longer. So, it should not move shackle back anymore only move forward when extended.
Can you say happy camper! Also in the not too distant future a build on Jolene, a 71 blazer that is going to skip all the tedious body chopping and go straight to tube from the start.
Removing those rivets without damaging the frame or the bracket takes forever. Then, many hours with a wire wheel and a flap disk later, I primed and then bed linered the frame. I've mounted my front spring hanger and rear shackle flip. Next, I install a rear cross member. I forgot to add that I have removed the saddle tank, too. And shortly will be installing the blazer tank.
