Smokey The Crew Cab---- 90 V3500 6.5 Banks equipped(Cummins Swap in progress)
Slowly making progress, parts are coming in at a snails pace! I decided to go with a GM t-case and keep the stock 60 instead of swapping in my 78-79 ford 60 . Saves me quite a bit of money rebuilding/regearing the ford axle at the expense of using 4” exhaust instead of the 5” I prefer.
I don’t really want to try that hard , the 4” Diamond Eye is gonna be enough hassle as is lol
Edit: I’m not even sure what down pipe I’m going to be using . I ordered a Borg Warner K27 from Power Driven Diesel . I have a 2nd Gen HX40 down pipe I can use , but I also want to run a PAC-Brake (preferably a direct mount)
I’m thinking I’m going to end up building a down pipe .
Also I’m not really wanting to spend the extra hassle just for the sound . It’s a VE motor with fueling mods to make maybe 425hp 4” is more than adequate. Is just like the lower tone of the bigger pipe.
My 98.5 has 4” straight and it’s the loudest truck I own . Smokey is gonna get a 4” Aero muffler it needs to be quiet I’d like people to think it’s still a banks equipped 6.5 lol
So this won't be on par to @obijuank5 's build by a long shot . I'm doing most of this build out of my hoarders stockpile . I am spending some actual money where I have decided I didn't want to compromise.
My budget is fluid, I'm using my Quarterly bonus checks from work, tax refunds, trading/selling, side work. No money from our monthly incomes is going to this project :( .
Specs: I will add stuff as I go along to keep track of the parts I have used.
90' Non-I/C 5.9 71,000 Miles
Bosch 370 HP Marine Injectors ( I bought OE Cummins nozzles on Ebay and built my own, I have a pop tester)
ARP 425 Headstuds https://powerdrivendiesel.com/product/89-98-dodge-12v-12mm-headstud-kit/
Borgwarner K27 Turbo https://powerdrivendiesel.com/product/borg-warner-turbos-k27-turbocharger-450hp-bundle/
Steed Speed Exhaust Manifold https://powerdrivendiesel.com/product/steed-speed-12-valve-angled-t3-manifold-in-stock/
Hamilton 178/208 Cam , lifters, pushrods, and valve springs https://powerdrivendiesel.com/product/12-valve-towing-cam-combo/
M4 Fuel Pin http://www.mandhinc.net/DPD-1-F.html
4200 Gov Spring (Stock Bosch part I found on Ebay )
AFC spacer http://www.mandhinc.net/DPD-4-S.html
Timing Spacer http://www.mandhinc.net/DPD-3-D.html
Extended screw https://puredieselpower.com/dodge-p...cummins-extra-long-fuel-adjustment-screw.html
PDD Tappet Cover https://powerdrivendiesel.com/product/pdd-billet-tappet-cover-only/
Hungry Diesel Piston Lift Pump https://www.thehungrydiesel.com/#!/Low-Pressure-Piston-Lift-Pump-Kit/p/440199397/category=0
Throttle Linkage adapter https://adventurevehiclesnw.com/sho...chevy-truck/cummins-ve-pump-throttle-bracket/
Billet Freeze Plugs Ebay
Hybrid NV4500
I rebuilt this trans and had it behind a 8.1 in my 71 GMC ( the 8.1 was a huge disappointment)
It now has a Cummins 1-3/8" Input and Cummins Bellhouising and I have ordered a Cast Iron Tailshaft Housing
https://www.allstategear.com/NV4500...m_source=googlebase&utm_medium=shoppingengine
Tennessee Diesel Conversion Clutch Hydros @CrewCab59
Southbend 3250 Dual disc https://powerdrivendiesel.com/product/sdd3250-6-org-south-bend-dual-disc-clutch-550hp-1100ft-lbs/
NP205 (1990 V3500 from behind a TH400)
32 Spine front Output
1410 flanges
Advanced Adapters spacer kit https://www.advanceadapters.com/gm-nv4500-to-gm-np205-circular-tc
Dodge SRW Dana 80 Rear axle 4.10 geared Factory Limited slip
Disc Brake Conversion https://lugnut4x4.com/product/dana-80-single-rear-wheel-brake-kit/#choose-your-rotors
Rob Bonney Fabrication Aftercooler mount and CBR Radiator with Spal Fans and a Vintage Air Monster condenser
https://robbonneyfab.com/cummins-swap-components/
Agan Fabworks Cummins mounts https://aganfabworks.com/product/afw-chevy-cummins-swap-kit-diy/
Proform Fan Controller https://www.proformparts.com/produc...fan-s-controller-push-in-and-thread-in-probes
ORD 1" Body Lift https://www.offroaddesign.com/81-91-gm-1-ton-crewcab-truck-1-body-lift-kit.html
Ugh , so no progress on this thing . I did get another NV5600/NV241DHD with the big input. So I will be using that instead of the NV4500/NP205
With the dodge tcase I will now be using my 78/79 Ford Snowfighter Dana 60 I have been hoarding for 15 years . The other optionis to use 05+ Superduty 60 I have with Hogback Fabrication swap brackets. But the Snowfighter 60 is the easier/cheaper option.
I need to start making some progress on my projects or just purge everything because stuff is starting to rot out from sitting.
I know the feeling.
I am now unemployed and spending time on going through what I have been hoarding and trying to purge and focus
5 years ago.
I was doing construction management for the past 5 years.
I am working on a few options to do the same but with different companies
Ever think about coming up here to AK ? Lots of that type of work here during the summer season.
How’s Anchorage? I’ve been offered a job up there but I have no idea what to expect in Alaska. It’s a 7 month on 5 off job, pay is great, I’ve always wanted to see Alaska but not sure I want to live there
Not looking at relocating.
Plenty of opportunities here.
I have 10 options right now, I just need
Anchorage………. It’s a liberal cesspool , at this point it’s basically Portland-Lite.
But , that being said Alaska is awesome. I can’t imagine living anywhere else .
Is it true that you don’t pay income tax in Alaska?
Yes , that’s true and no state sales tax.
Our property taxes are kinda steep for the services we get.
But all and all it’s not bad.
Wyoming also has no state income tax.
Very Cool!
We get taxed 5 times over.
Funny how it can work out for some states, and not for others.
Makes sense that resources pay out. And not screw the residents.
Very Cool!
You guys get ****ed by the rest of Canada,
So like New Hampshire, no state or sales tax but high property tax.
They have to get their money somewhere
Most of our budget comes from Oil/Gas and Mining royalties.
Municipal and Borough (county) budgets are paid by property and in some places small sales tax.
Our legislative body is very corrupt, I would predict in the next 10 years we have state taxes.
