Bah....Only reason I'd ever use it is if I absolutely had to weld something in the wind. And penetration isn't an issue on .120 wall material.
tRustyK5 said:Just watch you don't touch anything grounded with the contact tip...or you'll be replacing it a lot sooner than you planned.![]()
I'd certainly go as far as you can possibly go with the nozzle on, then try for the last bit without.
Rene
tRustyK5 said:It's also a lot more mobile...maybe you just need more practice sweetie. I don't have any trouble making flux core look good.![]()
Rene
Same for Microwire and Aluminum Mig.
tRustyK5 said:I just re-certified on my flux core a couple of months ago. Unlimited thickness, all position. Radiograph tested.Same for Microwire and Aluminum Mig.
I was referring to the little home job flux core though...you do know how to make that look nice don't you?![]()
Rene
skelly1 said:There's a concept here that got brushed over a bit. When do you want or not want the cage to be tied to the frame?? If it's not tied to the frame, it's just tied to the sheet metal floor then? The reason I ask is that I am about to pay somebody to do a cage on a Manx car, and if I like his work have him do my K5's cage. Obviously, I'll need to give him some detailed instructions.
tRustyK5 said:It may not be as pretty, but it sure as hell penetrates better...plus, when you're in very tight quarters you can remove the nozzle with flux core. As long as you don't touch the contact tip to anything grounded, that can make the difference between getting the entire weld in or not.
Rene
\\If you look a few pages back, Mudzer was saying how Tim put the A pillar bars in upside down. If put in the other ay, they bar would be a little closer to the dash and have a similar angle bend as the factory window pillar.blacksheep10 said:I can't believe how intrusive that bought cage is into the cab area. That A-pillar bar is WAAAAY out there. I know it is hard to get around the dash, but there are a few bends that could have remedied that. Still cool, always a good idea to have a cage protecting you. Going to cage a 79 of my friend's next week, will post pics on Pirate and link here.
Yeah, I had read all of that, but still couldn't believe it was that far out and in your faceEmmettology 101 said:\\If you look a few pages back, Mudzer was saying how Tim put the A pillar bars in upside down. If put in the other ay, they bar would be a little closer to the dash and have a similar angle bend as the factory window pillar.
tRustyK5 said:Yeah, there is no kit you're gonna find that will hug all the interior contours with 1/2" clearance...
Rene
