SOLD: used quadrajet 4bbl carb
It says "Delco Remy" on the distributor cap. I assume that's the brand.
You might be better off adapting an electric choke instead of trying to make the heat version work, although I've never seen an electric choke on a chevy to know how.
Edit: Here's a kit that says it will convert from hot air to electric: (Scroll almost to the bottom of the page)
http://www.carburetion.com/quadrajet.asp
The carb was fine when you pulled it off, correct? IE probably doesn`t need a rebuild?
