specific make/model recommendations for AC components
Forget all of it and do a full-top conversion? :hack:
How do you know how much oil is in the condensor? Hasn't it been in the system running?
Compressor is new, ran it for under 3 hours total. It's label said it had 3 oz of "PAG oil" in it which was drained overnight and replaced with 3 oz of ester oil.
  • Don't add any oil to the condensor since 1 oz was already added when it was installed and it hasn't been flushed
It just reads like you don't realize the oil is constantly moving through the system. Wherever refrigerant goes, it carries some oil, so there is always a supply for the compressor. You found debris in the system - didn't you flush the condensor after that? I've never heard of a compressor barfing and not flushing everything.
And I thought you were moving away from ester to PAG150?
Would you flush a condenser? If the condenser were flushed I'd add an ounce of PAG 150 to it
Yes, I'm using PAG 150 which AFAIK is compatible with ester.
Thanks for your help!
They say that a parallel flow unit can't be flushed. Tube and fin certainly can. You found debris in the screen. It's path there was through the condensor.
Awesome! I was thinking tube and fin could be flushed as well but read/heard conflicting info.
Thanks!
Also you can oil the parts in the compressor, but a R4 doesn't have an oil sump, so drain, or turn by hand until it turns easily and smoothly
