SPLATT'S 71 Monte Carlo
Thats an impressive pile o parts!
There's a disc brake kit, an a/c rebuild kit, full exhaust kit, 5spd manual kit, a new engine and related parts and a bunch of small parts to be installed. I've had a lot of those parts since 2014/15. And with all that I have a full cart on Summit racing.
I like first gen Monte's and I like even more that you're manual swapping it. What transmission are you using?
It's getting a Tremec TKO600 5spd although I wish the TKX was available at the time.
I forgot about this post and had to go back and see if it was the tko. They are good transmissions. As longs as you’re not doing 5k clutch dumps with slicks…
Nice! Plug wire management is so clean. Also I love those valve covers, I had an orange set on my 350 prior to LS swapping.
I doubt the car will ever see a set of slicks much less a 5k clutch dump.
I don't know how I missed this sweet build, but I am watching the rest of it....nice car! (I saw your post in the tool thread)
Time to fit up tires so I can get some wheels. I know they'll fit the rear just need to get the right specs on the wheels. While I'm at it I'm going to see if I can get them to fit the front with the same wheel spec as the rear. If that doesn't work I have a plan B for the front.
View attachment 483615View attachment 483616View attachment 483617View attachment 483618
Fancy.
I just have a couple of wheels I use then I measure how far I have to space it to make it work
