2 and a half hoursHow close to Ontario OR. are you?
You said you have axles?Here are some closer pics of the rust. It could be saved or built as a wheeler. As-is $250 would get it.
I have one rear van 14SF axle but no front axles at the moment.You said you have axles?
Title?I have one rear van 14SF axle but no front axles at the moment.
I have a clear WA title for it.Title?
Hmm getting is the Hard partI have a clear WA title for it.
Depends on how much and how can I get it from nw Washington when I'm in NE Oregon @2Dogs has a trailer
Another soon to be “someone’s” project rig?Flatbed removed and sold.
This one is my project. I haven't fully formed the plan yet, but it is going to be built as a tribute to my dad's 1978 K30.Another soon to be “someone’s” project rig?
Depth was the issue, not overlap. the box for the outlet being recessed behind the drywall means the outlet needs to sit on top of the drywall for the cover plate to work.You just need these...https://www.kyleswitchplates.com/largest-oversized-outlet-receptacle-cover-in-7-5-tall-size-white/?srsltid=AfmBOoqOx0l6ZlXFPNxoMwUGOTTbHZha7XjsBbTZsEx5qGBbHs-av4lr6Pg
You could use extentions for thatDepth was the issue, not overlap. the box for the outlet being recessed behind the drywall means the outlet needs to sit on top of the drywall for the cover plate to work.
Shortest one I've seen is 1/2" when I need about 3/16". I could have also put spacers between the outlet tab and box, but fixing the drywall was faster than driving to the store for more stuff. It is a two hour round trip minimum to run into town from where I live.You could use extentions for that
Oh 3/16" is nothing, and yes just having the tab do the job is easier.Shortest one I've seen is 1/2" when I need about 3/16". I could have also put spacers between the outlet tab and box, but fixing the drywall was faster than driving to the store for more stuff. It is a two hour round trip minimum to run into town from where I live.
