Streetgliderx
i don't fully understand X over steering but any thing can be fabricated
Something like that, but with longer links to the spring plates may work to clear the drag link in a x-over setup, but the driver's side link would need to be moved outboard of the spring pack to clear the frame which would require lengthening the sway bar.
BILTIT, any details on the aftermarket sway bar?
Sorry, didn't mean to hijack the thread this much![]()
The COG is 29.13" from the ground on a stock 79 Blazer.
4" of lift and 35" tall tires raise the COG about 12 inches from factory stock. A 41% change in height. This is the critical issue.
You weren't doing it right; you should have up two screens of porn.That's it. No more surfing porn while answering a serious question...I thought with two screens I could do twice as much....
I agree with your math BlazerBones. If anything you underestimated the unsprung weight and the COG would be lower (not higher). I would like to know where that 29.13" stock COG height number came from. I've been trying to come up with a reasonable way to estimate the COG height.
Can you provide some details on that program?
