Swettysblazer's 1991 K5 Trazer: ONE TONS!
Start jiggling wires when it does it. Does it only have trouble when it's a hot start?
No. Its random. I got it to run this morning, shut it off, no start. It did the same thing 20 minutes later. I am not getting power out of the fuse block to the fuel pump power wire.
Make sure the bulkhead connection through the firewall is tight. Had mine do that once, the screw holding the 2 halves together had backed out
Same problems before but random circuits. I separated the bulkhead connector, brake cleaned the goo out, wire brushed all the terminals and gooped it back together. Solved my random circuit cutout problem as well.
I noticed you replied in the midst of my second thought but anyways what about the pump connector? The LS swapped baby Blazer I did has a bad connector I'm guessing. Wiggle it a bit and it fires.
If i pour gas down the throttle body it starts. Which leads me to believe the ignition switch is good
I broke a bunch of shit this weekend. I decided to get stupid ( and maybe @Richcz28 talked me into it) and hit a whoop section which kind of launched the truck. Landed real hard, on the gas, and I think I bottomed out the driveshaft. From what I can tell just looking at it, I think the only thing I broke is the adapter from the trans to the T-case. A big thank you to @jekquistk5, @zimmer76, @Alan2smiley, @Deuling and everyone else who helped get me out, especially Dave for letting em use his truck and trailer to get my junk back to Nate's. Anyway, here are some pics from random photos on the Dunefest facebook page:
