Apparently the L31 cam is 191/196 at .050", (.414/428 lift) so there is a bit more to that cam than the TBI one.
I think your results somewhat vindicate what's been said about the TBI heads...in the truck applications they actually flow (and perform) pretty well. The heads you have now will probably benefit more from other induction/exhaust improvements than the L05 heads would have.
Edit: Personally I ignore the peak numbers when dealing with my truck, because that's not where I need power. Generally dyno tests are way off-idle, which doesn't give much of a picture for pulling power from a stop (particularly with a manual), but this testing shows a 30ft/lb improvement just past 3500RPM, and the smoother curves are going to result in better felt performance. Not to mention that looking at the 2500RPM numbers, the modifications are doing something even at lower RPM's. Not trying to push headers over everything, but this is the first time I've seen this "test", although it mirrors pretty much every other one I've ever seen...manifolds suck for performance, it doesn't matter which SBC manifolds you have, they cannot compete with headers. Unfortunately, the general tradeoff is the hassle headers often times provide. But if looking to eliminate hassle, then no mods should be attempted, because all of them result in some other complication, if they do anything worthwhile.
