Speedo cable (if he has one,I think he said he didn't--but in case anyone else reads this to find out the procedure it should be listed)..
After I had to replace the trans cooler lines and had it be such a pain to get at the fittings on the transmission,I decided to only use a short length of tubing (ready made ones with the line nuts & already flared) at the transmission,then used 5/16" couplings or compression fittings to join them to the longer tubes running to the radiator--that way if the transmission ever needs to come out,the cooler lines can be unscrewed at that junction next to the bell housing without any hassle..Also,the fittings in the transmission that accept the flared lines have a special straight thread in some cases too--don't try using ones with 1/4" npt pipe threads,they will crack the case!..
Don't ask how I know that..![]()
Im just going to spend the $ and get braided lines with the right angle connector at the tranny.
