Pulled the fuel lines out, found my leak and very likely my no fuel issues. Pretty sure the pump is ok, but going to change it since i have it.
Removed the adapter plate and dod some "machining" and assembled the Holley throttle body and spacer to the adapter plate
Then the wind go so bad i just closed the door, intake is still open.
Will start over tomorrow
BBC (stock) TB's use a different IAC. You may need one of those...
Although now that I look at it, you would still have to modify the holley one to use stock BBC IAC...
Shoved the SBC IAC in there. Verdict is out still, may drive it awhile. Idles ok, tad of an off idle stumble, but it might tune that out
It runs better, but the fuel pressure also went up 2psi at the injector
Wonder if it's the same IAC as the Sniper? If so, I cam get part number.
Hi tek enginerding to lengthen the e brake pull rod. Cut down the cable and recrimped the end
