I change my previous suggestion though.... :thinking:
8.1/Allison might be better. Lol.
But seriously, BB is the answer to all things truck :thumb:
8.1 good, Allison bad. Well in this application at least. They don't fit under a square without a huge body lift or major floor pan mods. Then it's integrating the controls for the Allison to work.
Plus the torque management that the Allison throws into the mix is a pain to tune out unlike the manual or 4L80e equipped 8.1's.
Oh and it's still a slushbox. Kidding aside, the strength of the Allison does not outweigh the crap that comes with putting it in a square.
I just always heard that they always seem to be in the right gear lol.
They usually are. But they do rob more HP than a 4L80e or nv4500. For all the issues, I certainly wouldn't go out of my way to put one in.
Yes, but I’ll get it through a solid tuneup, run the overhead, change the fuel filter and start over.
I’ll pull the pump off of it tomorrow
Probably pull the radiator and soak some scale remover in it
Shifting at 6500 rpm in anger letting the 3" pipes roar had nothing to do with it right?
Showing off for the Ford boys across the street again aren't ya?
Dude they brought another one home yesterday! Each one shittier looking than the last! My wife takes pictures of them now. It’s hysterical
Are you and Zoo neighbors now?
Fix the old girl up, and turn down the boost to make it stop popping and farting.
Not quite, but Bent has joined the Pueblo contingent of CK5. He's actually a couple minutes away from Larry's place, 20 from mine.
I was over there getting boxes from him when we saw the neighbor pull in with one of the greasy ford's.
Hammer that required service before use - Check
Impact - Check
2x4 - check
F'ed up tailgate that needs replaced - Check
Tailgate works amazingly well when all of the fun internal parts are lubed and not bent to crap
Hoser Air doesn't fit so hot, hits the dizzy. Hey @ZooMad75 or @Larry one of you guys have a 1" TBI air riser?
