B
Bent77
Guest
Fuel filler should be easy to sort, since the tank got moved to the Burb position. Was thinking of taking the hard tube and all the clamps loose and letting it rideJust watch the fuel filler assembly, even after it's loose it likes to snag on stuff. And the wiring of course. I just put 4 hooks in the ceiling and used 4 straps in the 4 corner stake pockets, was very controllable.
I like the Stake corners as a point. It will have to get pulled outside though. There’s so much crust and BS on the bottom, I’ll never get the shop clean if I wire wheel it. Probably need to blast it, too
