But if you are looking at NWF for a doubler, you don't care about which drop it has! The planetary set goes into their box.
And that 465 had a 32 spline....
Yeah there's others at that price closer and such.
Quit slacking and find me stuff. Ervin even called me to see what to hunt for...
Maybe I should offer a bounty for the finder...
Here it is for all you bounty hunters...
1) Used doubler
Or
2) 203 with the adapter off of a 465
Or
3) sm465/241, but not a bastage drop...
I have located a known good 465 32 spline w/ 208/241 adapter at the correct price. Kinda looking to see what else shakes out...
What should the bounty be
:thinking:
And if you would have started this 2 months ago, I had the 465, with 208 adapter that I sold for $50....
But you're slow.... or late.....
You didn't offer...
Find another one....beer...
You owe it to yourself to do something better than a 203/205 if you have willing help.
Buy the 465/241 combo.
Who cares if it drops the wrong way.
Leave it long. You have a longbed. You have the room.
Remove the tail housing (only the rear most part) and have machinist friend fab up an adapter from there.
Convert your 205 to 32 spline.
Build a simple shifter to reach all the way back there.
Build crossmembers.
Adjust driveshafts.
You could clock the 205 all the way up because the front shaft will be so long.
Rear shaft should still be plenty long with the longbed wheelbase.
There are some 465/241s here in town. Most priced too high, but they are here, and not bastage drop.
Issue with that is I also need SYE or go straight to a 241/205 doubler $$$$
If I go NWF, I can use my crappy old 205 as is, 10 spline and all. Then only have to buy some stuff. Or be a cheap bastage and make stuff. Even the drive gear stuff can be done
