He said that they built the box that is on the K5. It works nice!
But he told the boss to go see them for his and it has a leak. Hopefully it is a fluke that gets handled.
That upset me. Recommended to the big boss and fail. Only guy I have ever heard of an issue
Is it on yet?
It been well over an hour!
I'm out of lug nut snacks.....
Is that the later, small shaft then?
bite me...
Its on, had a few malfeasans to work out. Bled it once good after i cut the shaft apart and made it for the large drive couple. Like that better than the XJ one anyway.
Its like, dark here. Pictures manana
No leaks yet, if it's wobbly I can't see it.
Still needs hydro
In place. The bolts thread into blocks welded to the bed, so I can remove them and the block is flush with the bed ridges. Hi lift and spare mounts are the same.
So when I'm not 4 wheeling it can still do work
