B
Bent77
Guest
If you guys change your minds, change your vote!
Yeah that was actually a factor. With the Doubler to go the other way, 37s on 4.10s adds a little leg on the highway.Needs a red and blue pinstripe around the rim to complete the look. 37's should have a nice overdrive effect for that 465 won't it?
My 35's with 3.73's was good on the highway. Just really soggy from a dead stop or climbing grades. That probably had a lot to due with the worn out 350.Yeah that was actually a factor. With the Doubler to go the other way, 37s on 4.10s adds a little leg on the highway.
10% difference in the tire height, drop 270 RPM at 70
Yeah, I just use that 6.55 to take offMy 35's with 3.73's was good on the highway. Just really soggy from a dead stop or climbing grades. That probably had a lot to due with the worn out 350.
