So, I am not a tbi or fuel injection guy on these trucks. Only ever had carb or diesel. This pump is just a camaro "high" performance pump and then you regulate it down to the low pressure you need correct? Does tbi run a regulated return style setup and just dumps all the extra fuel back to the tank?
Yes. Start at 12 PSI
I with with AC Delco with the Sniper but I debated hard about doing Walbro's. Back when I was buying new pumps for the TBI I read several negative reviews on AC Delco pumps so at that time I went with Bosch.
If the AC craps, I'll warranty it as a spare and go to a Howell frame pump
Had issues with my Walbro from the start. Purchased from Summit. Got rid of it, went delco TPI camero pump, works great. Walbro went maybe 4 miserable months, loud and pissy. Changed for Delco, quiet and reliable, running maybe 5 years now. Changed nothing but the pump at the time.
Just one mans experience with only one pump. Not much to make a decision on, but I'm set which road I'll take from now on.
