Hurry up and get it installed :pimp:
Wish it was that easy
Not that I'm wrenching on it today, but Summit focked the dog and shipped my parts somewhere else. So missing all the fuels system parts I need to rebuild that mess.
For what its worth, they wanted me to pay them for a second shipment even though they focked it up.
Waiting for parts from Jegs
So the to doo-doo list
Throttle bracket
Build/modify throttle lever to work with the truck linkage. Tis uses the pin style
Ignition
wire
plugs
oil change
relocate pump wire
relocate 12V wire (both are under dash now. Not crawling under there again)
Wire in Edelbrock system
Check/rebuild/repair the fuel system
add regulator to fuel rail and hook up vac line
change -6 AN line ends from straight to 45* to take pressure of the line
coolant
EFI setup on tablet
Well that sucks, kind of hard to believe I thought summit was better then that.
Third time for me. I only ordered the PF4 from them because both Jegs and Edelbrock were back ordered.
Next time I will just wait for Jegs
To further drive the point, the cust service rep was atrocious.
I hate summit
My last order from Summit came from all three distribution centers and arrive within 2 days.
Dang recall tsb's coming out before parts are available.
That's a typical GM move for sure.
Back to the Bent one's issue, good progress. Hopefully you have a little time off coming near the holidays where you can get some garage time to work on that list.
Well I’ll keep plucking at it but don’t anticipate huge gains with the holidays.
We’ll be in your hood next weekend
